2020 honda insight touring
Just bought a 2020 honda insight touring and the 6.5 speakers in the back sounded really bad. I replaced them with Kicker ones and they still sounds bad. What could the issue be?
It sounds like you're dealing with a frustrating issue regarding your audio setup. Here are a few potential reasons why your new Kicker speakers may still sound bad, along with some troubleshooting steps:
1. **Speaker Compatibility:** Make sure that the new Kicker speakers are compatible with your Honda Insight's audio system. Check the impedance (ohms) and sensitivity ratings. If the speakers are too low in impedance, it could lead to issues with sound quality.
2. **Power Handling:** Ensure that the speakers can handle the output from your head unit or amplifier. If the speakers are underpowered, they may struggle to produce quality sound.
3. **Wiring Issues:** Double-check the wiring connections. Poor connections or damaged wires can lead to distortion or low sound quality. Make sure the positive and negative wires are correctly connected to each speaker.
4. **Speaker Placement:** Sometimes, the placement of speakers can affect sound quality. Ensure that the speakers are mounted securely and that there are no obstructions around them.
5. **Equalizer Settings:** Check the equalizer settings on your head unit. Sometimes, the factory settings may not be optimal for your new speakers. Adjust the bass, treble, and midrange settings to find a better balance.
6. **Head Unit Limitations:** If you're using the factory head unit, it may not have enough power or features to drive aftermarket speakers effectively. Consider upgrading to an aftermarket head unit that offers better sound processing and power output.
7. **Sound Deadening:** If the car has not been soundproofed, road noise can interfere with the audio quality. Adding sound deadening material can help improve the overall sound experience.
8. **Subwoofer Integration:** If you're looking for more bass, consider adding a subwoofer to your setup. This can relieve some of the strain on your 6.5" speakers, allowing them to perform better.
If you’ve checked these factors and are still having issues, it may be helpful to consult with a professional installer or audio technician who can assess your system in person.
Feel free to ask if you have more specific questions or need further assistance! Other members are welcome to chime in with their experiences or suggestions as well!
dustyblunk19
dustyblunk19
Ohio
maylar
BP1Fanatic
    Jun 2, 2026
BP1Fanatic
    Jun 2, 2026
