OldHeadBASS
I've never seen a high end build in a Acura mdx so , I do know where to start looking for alternators. I'd like to do about 6k total.
If you're looking for advice on building a high-end audio system for an Acura MDX or need help with specific components, feel free to ask!I've never seen a high end build in a Acura mdx so , I do know where to start looking for alternators. I'd like to do about 6k total.
Thanks !Parts Search - High output alternators for Car Audio Made in USA
Find the right high-output alternator for your vehicle. High amperage alternators in 30 different colors. Find your make and model.autotechengineeringusa.com
Looks like they've got a 240 and a 320 option that would fit.
Seth is known to embellish the ratings on his battery. I'd recommend getting a diy kit from sriko batteries instead.Look into a GloweVoltage Series 1, 2, or 3 before you do an alt upgrade. A good size AGM under the hood and a GloweVoltage series 1 in parallel power my 4500 watt system all day long without a hitch.The series 1 will support up to 8 K audio systems on a stock alt.
And they are finally back in stock!
If you do decide to upgrade the Alt, these guys are an excellent source. Fill out the email sheet questionnaire, they will email you a replay on what is available specifically for your car. Great pricing, great customer service and super knowledgeable.
Not at all.Seth is known to embellish the ratings on his battery. I'd recommend getting a diy kit from sriko batteries instead.
ThanksLook into a GloweVoltage Series 1, 2, or 3 before you do an alt upgrade. A good size AGM under the hood and a GloweVoltage series 1 in parallel power my 4500 watt system all day long without a hitch.The series 1 will support up to 8 K audio systems on a stock alt.
+1 autotech.Parts Search - High output alternators for Car Audio Made in USA
Singer alternators. Honda/Acuras have really aggressive voltage regulators and he was at least when I inquired the only major aftermarket guy that had a bypass for it.
