2012 Toyota 4Runner SQ+ build
So how much better are the APs
I haven't tried the tweeters yet but the 6's and 2's are awesome. I'm not smart enough to say why they are better, they just sound better. The midbass is awesome. A lot of people run tweeterless using the 2" but I'm not going that far, I like having tweeters.
I'm not familiar with the w3's but if your winning competitions they must be doing something right, congrats !!
Time for an update on my new pillars. I worked about two or three hours for three days on them and got them ready to cover.
I ordered four way stretch vinyl to do the job. Unfortunately, I received zero stretch. I decided to try anyway.
Unfortunately, it didn't work out. To make it worse I decided to try the other pillar with some two way stretch vinyl I already had. That didn't work either.
This is how they looked after I pulled the vinyl back off. Kind of remind me of Freddy Kruger.
It took some time with Acetone and a green scuff pad but the glue did come off. Unfortunately the vinyl had pulled some bondo off as well. //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif
After a couple of hours of cleaning I got back to work on them. This time I added primer to make it easier to get the glue off if I screw up again, or whenever it's time to build them again.
Replacement vinyl should be delivered tomorrow.
It took three attempts, but the pillars are finally covered, dyed, and installed.
Audible Physics tweeters with quick connects.
A few awards from my first show with the new pillars.
Best of best of show.
Best of show SQL.
First place street install.
Second place SQ Street.
First place park and pound 1.
Second place SPL Street 1.
Overall It has been a pretty good first couple of months competing. I have been to seven competitions so far in states including OH, VA, KY, and TN. I've heard a lot of very nice sounding cars and met lots of good people. I'm having a great time playing around in this hobby.
Thanks for the link to this video, I've seen this one before but it's not for component speakers which is what I'm going to install and the part...
741
Try crutchfield.com and use the application that gives you replacement options for system components. I ripped out the entire system in my Mustang...
It is in eBay. It is a bit more complicated. You clip off the gray blocks on your radio's harness and splice in the new harness by color matching...
Nice, much better looking version Ford than its American counterpart. Go down to the local stereo shop and tell them you want to the work yourself...
lowcel
lowcel
Charleston, WV
Bacovish
    May 24, 2024
