2000 Toyota 4runner Install 56k not recomended.
I think Super Street and extreme are the only ones that you can run multiple batteries.As far as them just setting in there and not being connected I couldn't tell you.
Well they have absolutly no rules posted saying I cant have more batteries I have read through there rule book several times. But I had planned on that just in case it was an issue so i could run just stock batt up front
It is in there. This is direct from the rule book.
Competitors in the Street A class are limited to a single 650 cubic inch (10652 cubic cm) or smaller battery. Competitors in the Street B class are limited to a single 800 cubic inch (13110 cubic cm) or smaller battery. Competitors in the Street C class are limited to a maximum of two each 800 cubic inch (13110 cubic cm) or smaller batteries
bummer they didnt say anything on there site about batteries or at least I couldnt find anything
Twist both grounds together. Good call on checking power with a multimeter. I assume you have pulled out and re-inserted the fuses, so as a quick...
I only have experience with ct sounds. I have the ct80.4 and the ct1500.1 in my sons camaro he is playing them everyday I had the 80.4AB go bad...
The last piece and the system is a wrap, RUX-H02 remote volume/sub knob because we are old and buttons **** IMG_0647 by Jon Polo, on Flickr...
bumpin buick
Science is everything
bumpin buick
Appleton, Wisconsin
kovemaster559
    May 16, 2024
    May 16, 2024
