2.5" Port?
  • 4
Heeltoeclutch
So I'm nearing completion of the box for my DCON 10" (1 cube) and was planning on using 3" PVC for the port, but as it happens the 3" right angles are too huge for me to get anywhere near the port length desired. I am wondering - would it be a cardinal sin for me to use 2.5" pipe instead?
Thanks guyszth //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
That's what I mean - the elbows are so damn huge I can't fit two in there for the port to double back on itself as I had intended.
Heat gun will take care of the flares.
You should be fine with a 2.5" port, if you want to put the link to the t/s parameters of your woofer I will check vent mach for you.
Yeah, saw that too, was like ??? wtf! They do know there stuff, I usually just roll with it!
13
You could try to make the port longer, but there might be other reasons with the box won't extend lower, or even the sub. You'd have to reverse...
763
While that program is pretty neat, it assumes you know the values. I was just recapping the numbers you provided. RS recommends the following...
945
920
Yup. That is the bread truck that Richard Clark built for MTX many years ago . 60 inch subwoofer. The problem was that the truck wasn’t...
14
Heeltoeclutch
Heeltoeclutch
San Diego, CA
Kangaroux
    May 24, 2024
