2 15" subs!!! WHICH ONES!?!?!
it is quite a craftsman and audiophile.. yeah, i guess it wouldnt hurt, i just slapped in a bass tone and played in incriments from 40-55hz and layed the front seat all the way back.. didnt fool any with the amp gains and had my hu sub on -10 as well as all setting except front-rear speaker adjustments.. i also developed a ground loop hum right after i metered.. i gotta fix that
If buying the CVX's gives you enough money to get the AQ amp or a MTX TA 7801 that does 1200@1ohm, then that would be a good plan. IF you can afford the SD2.5 then they are a high quality sub and you will have made a good decision.
The DD 9515 is an insane deal, by far the loudest option on clean power.
I am on the verge of ordering the 2 Kicker CVR's which are under $250 shipped.. The deal with the DD 9515 did not work out because right now I do not have the money to afford an amp that will sufficiently power it. I am pretty sure that I will be ordering the 2 Kickers and a Hifonics Brutus BXi 1606D for around $500 for everything.. How will that setup sound? And will the hifonics amp actually hit the rms wattage it says it will?
Americanstrat21
Americanstrat21
Rockford, IL
Americanstrat21
Doxquzme
    Jun 20, 2026
Doxquzme
    Jun 20, 2026
