2 15" subs!!! WHICH ONES!?!?!
my friend has a 92 jimmy we just finished his box and his wiring all showed up 2day. we managed 7.8cubes net tuned to 35hz w/ 113sq.in. of port running 4-12s and 1200watts...
under 3 for a pair of 15s..i guess you could go for a pair of used memphis subs.. i think you made the right choice w/ 2-15s instead of 4-12s..imo
the CVR's dont look too bad at all u can prlly put a little over 1k to em too..
Well... I found those kicker 15" how do you think those would sound? I think the RMS of that amp is 1200.. these 15's put out 500 watts rms ... ?
Should I get these kickers or get like some Pioneer Champion series 12"s?
Or maybe even a really nice single 15"??
Reccomendations please!!
Audioque HDC3-15...ftw... 6cubes net, gobs of port area tuned to 30hz..done:greedy://content.invisioncic.com/y282845/emoticons/greedy.gif.5a53e6246569d7ab79867170f3b06629.gif:greedy://content.invisioncic.com/y282845/emoticons/greedy.gif.5a53e6246569d7ab79867170f3b06629.gif:greedy:
Which one? The kicker Comp VR 15" brand new for $250 ?? Or the single Audioque? I need dual 4 ohm subs I believe because I have a monoblock amp right? I can't get any other subs unless they are dual 4 ohms?
1. Could you tell us who makes your amp?
2. At what ohm does your amp make 1200 rms?
Get 2 of the AQ SD2.5 15" subs my .o2cents
the amp can "handle" 2 15" subs just fine, as long as they are 5-600rms no problem.
I am thinking about buying 2 15" Orion HCAA dual 2 ohms.... I would have to get a new amp then too but... If I got 2 15" Orions for $500 do you think that is a good deal? They were manufactured in 2000...
Americanstrat21
Americanstrat21
Rockford, IL
Americanstrat21
Doxquzme
    Jun 20, 2026
Doxquzme
    Jun 20, 2026
