2 10w6v3 and ported enclosure 500 bucks!
ITS THE FL TWEETER IS THE NAME OF THE OUTPUT ON THE CD PLAYER THAT WAY I AND CORRELATE IT TO MY CD PLAYERS OUTPUTS WITHOUT GUESSING. plus im ******* aroundhere
doing this would give me more controls without hooking the laptop up. all i have to do is keep the crossover FLAT on the CD player or defeat them completely
That's not what you do.
You have a Left and right full range channel.
They go 1- Left
2- Right
If you want sub control from the HU you can add 3- sub. If you want to control the sub level from the DSP remote you don't have to add it's input.
You did the same thing we clowned John for.
That's because you're weak and stupid.
have you actually used it? it has a **** ton of features thats PLENTY. 31 band parametric EQ independent for all channels Q from .1 to 20. four xover types including a variable Q up to 48db per octave! **** i know i could whip **** rider here with this thing..
That's not what you do. You have a Left and right full range channel.
They go 1- Left
2- Right
it doesn't matter which input to output you use. all of the inputs can be used to do anything. 1 2 3 4 5 6 7 8 is full range with bandpass able crossovers
No I haven't. It was just a joke after what Losisatool posted.
They go 1- Left
2- Right
my DC player has 6 outsputs
left tweeter
right tweeter
let mid
right mid
sub 1
sub 2
you cna LINK the outputs. the last two channel (7 and 8) wont be used for a 3 way system
left tweeter
right tweeter
let mid
right mid
sub 1
sub 2
That's if you are in network. If not they are all full range.
ALL THE DSP NEEDS IS LEFT AND RIGHT FULL RANGE.
Simple stuff
Im literally naming the inputs after you FBs.
---------- Post added at 07:17 PM ---------- Previous post was at 07:16 PM ----------
that's if you are in network. If not they are all full range. All the dsp needs is left and right full range.
Simple stuff
it will be full range coming out of the cd player
you can't comprehend just know i KNOW. its to gain control of my levels and make even more adjustments.do i have to make a video and show you?
---------- Post added at 07:20 PM ---------- Previous post was at 07:20 PM ----------
+1. you 're climbing up..
I call people that on a daily basis. Especially at work.
Here. It's a series
you don't see the curves? channels 1 and 2 or the tweeters crossed at 3000
outputs 3 and 4 are the midranges bandpassed from 75 to 2950
7 and 8 will be used for the woofer. crossed at 70hz
the output from the CD player are Left tweeter
right tweeter they will be full range
then left mind and right mid. they too have defeatable crossovers that will be full range
then sub1 and sub 2 wil ALSO be full range!
what don't you grasp?
you don't see the curves? channels 1 and 2 or the tweeters crossed at 3000 outputs 3 and 4 are the midranges bandpassed from 75 to 2950
6 and 7 will be used for the woofer. crossed at 70hz
What the **** are you talking about? Homie just slow down.
Inputs.
You don't need all 4 outputs from the deck. If the decks filters are off you only need Left and right. It don't matter what it comes from.
Also sub is mono. It only needs 1 output.
What the **** are you talking about? Homie just slow down. Inputs.
I know. But if i use them I can make adjustments through the CD player.
I can adjust the l/r balance and output on individual drivers/ outputs and t/a if i need small tweeks.
Every arist is a tad different. I like to fine tune it to my perference..
DarkKnightSM
DarkKnightSM
Co Springs
DarkKnightSM
