1ohm VS 2ohm vs 4ohm
It really depends on what the amp is DESIGNED to do. Most are more efficient at higher impedence, but will give you a lot more output at lower loads. It is generally accepted that higher impedence sounds better.
Typically we're trading off between cost/power output vs. consumption/size/etc.
Id run the JBL at 4 ohms and just do the big 3 with a run of 0 guage to the back, i think thatll keep it happy, and if not then through a cheap battery in the back to keep the volts up.
moparerrnocar
moparerrnocar
Fargo, ND
moparerrnocar
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
