1ohm or 2ohm stable amp more efficient ??
Jeepjones85
Gold Power
Im looking at buying a kicker zx 1500 or something else thats 1ohm stable:confused:
So I guess my question Is which amp would be better a 1ohm or a 2ohm
stable amp? Iv heard that the 2ohm stable amp can be more efficient and cause
less of a strain on your electrical system ??
This will determine what ohm subs I buy. Thanks for any help
2 ohm amp will put less strain on the vehicle and normally is more efficent. the zx can be ran at 1 ohm but you have to know what your doing and be careful about it. its recomended to be ran at 2 ohms. mines running at 2 ohms and it puts out around 1800 rms
well I know this is a big difference but the kicker zx 1500.1 compared to the hifonics 2608d 2600watts rms
somebody told me the kicker would still be louder because it is a kicker and it was 2ohm stable
Is this true??
A 2 ohm load would technically be less strenuos on the electrical system, but will the efficiency be any better? In my opinion...it depends on install/box/amp settings. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Ok thanks. Im lookin to power two kicker CVX 15's they are 1000w rms each in a sealed box for SQ and Iv got about 400 to 500 $ to spend... What kind of amp would yall recommend? I dont really want to buy a used amp because Im not sure what its been through.
well I haven't ordered them yet it will be the end of next week but Im leaning to
dual 2ohm so I can wire down to 1ohm. There seems to be more options for 1ohm stable set up's
well I know this is a big difference but the kicker zx 1500.1 compared to the hifonics 2608d 2600watts rmssomebody told me the kicker would still be louder because it is a kicker and it was 2ohm stable
Is this true??
HAHA!
Oh, God.
JL IS LOUDER CAUSE IT COST ME $2,000 DOLLARS! THERE'S NO WAY YOUR $250 DOLLAR COULD BE AS LOUD! IMPOSSIBLE!
It's BS. A lot of amps are 2-ohm stable, and whether or not it's good for your sub is based on the sub.
As for efficiency, regularly, the higher the ohm (In #), the more efficient it is. However, there are amps which are designed to be efficient at low-ohms.
However, the power gains in most applications is a lot when stepping down from 2 ohms to 1-ohm. For instance, an amp that does 600 x 1 @ 2-ohms can do about 1000 x 1 @ 1-ohm (This is just hypothetical, even though there are quite a few amps which can do these exact numbers).
Some amps will have an efficiency chart, or will say they are % efficient at ohms.
Jeepjones85
Gold Power
Jeepjones85
South-East AR
helotaxi
vegang
vegang
