1ohm or 2ohm. Need urgent help!
sihin
Hi all. I have a Autotek amp which states 2ohm @ 500rms, 1ohm @ 800rms so right now i need to power a single Alpine Type R rated at 500rms.
Need somebody to help me whether i need to purchase the woofer for a 4ohm or a 2ohm?
Problem is whether my amp will get very hot at 1ohm? or i just purchase a 4ohm sub or 2ohm.
Hi All sorry, sub will be a DVC
why? dual 4 will give a 2ohm final load... dont type r's take more than 500w? I say get a dual 2 and run the amp at 1 ohm. if the sub sounds like it cant take the heat, turn the gains down.
i would rather you stay in the safe side and power it 500w @ 2 ohm.
and if u want to power it 800w @ 1 ohm, you'll need to purchase the Dual 2 ohm type r.
my main concern
right now i have two sub to choose
Type r DVC SWR-1224 4ohm, Type r DVC SWR-1222 2ohm
My amp spec mono black, 1ohm 800rms 2ohm 500rms.
whihch 1 i should use? i know that use in 1ohm load will be better but will i overheat the amp for long time usage?
But if i use a 2ohm load will there be enough power to push the sub to the max?
my main concern
omg.... nevermind bro.. nevermind... i thought i already told you....
if the amp is 1ohm stable then it should be able to handle it fine
800w will be good, just turn the gain down if the sub cant take it
get d2...
if the amp is 1ohm stable then it should be able to handle it fine800w will be good, just turn the gain down if the sub cant take it
my main concern
500w will push that sub no where near its max...
sihin
sihin
Singapore
Mr. Opportunist
vegang
vegang
