I decided to place the sub on the front and double baffle it. I have another section of 1¼" dowel left so I may add some more bracing from top to bottom, think I need it?...hes going to double baffle it.. which means hes going to have to cut his port and shit aswell.
X2 I use the concrete mold tubes and just hack out sections to get the rounds.foil some PVC, stick it against the corner,clay the edges where it meets on the outside of the pvc/wood joint, and pour in resin. rounded corners >45*
Actually, you don't want to use that much resin in one spot. When you pour on resin that thick, it tends to crack over time, especially in a corner.foil some PVC, stick it against the corner,clay the edges where it meets on the outside of the pvc/wood joint, and pour in resin. rounded corners >45*
I'm using a Planet Audio thats birthsheet is 2257rms @ 1ohm ...oh and what amp are you gonna be pushing that beast w/?
true that. you can always mix the resin with a little saw dust to give the resin a little filler. it doesn't weaken the mix, it makes it denser and you end up using less resin that way.Actually, you don't want to use that much resin in one spot. When you pour on resin that thick, it tends to crack over time, especially in a corner.
