That's all max power. It puts out like 1,500 @ 1 i think. It's pretty much just the mb quart 1500So does the mm4000.1D make the specs of 4000 watts or is that just BS? I havent seen them yet
it can only do 1500-1800 at best with 140amps of fusing i know fuses dont indicate power but there no way in hell your gonna get 4k in that size package for that priceSo does the mm4000.1D make the specs of 4000 watts or is that just BS? I havent seen them yet
its the same as a hifonics brutus 1600That's all max power. It puts out like 1,500 @ 1 i think. It's pretty much just the mb quart 1500
what class you gonna be running in? will definitely see you there. whats in the car right now? are your wires run inside the car? through the seats?amps 1800 @ 14.4 the cuts are straight lol..(that 1 cut im not worried about...)
as far as the sac show everything is looking good..this box should be done by then.
i have to so some electrical beefing up and sound deadening
your not a 150 bro. not that close to it either from what i can see.setup is in signature.
wire's ran through car through back seats...
This setup is unique in alot of ways(1 my current box trunk setup which you have not witnessed).
This thing is as loud as my buick with 2 15 cvr's in a prefab ported (trunk)
and its as loud as my buddy's 2 15 cvr's sealed (800 watts) has a arm rest port(i did the install)
far from 2 comps it's built to be loud on the inside...
