150db trunk car Little attempt at big bass
Yeah , sometime when me and thevic24 get some free time i will be swapping the USX-800F over to midbass duties and installing a Fusion NV-AM 25001D. Which as it stands now (pair of dcon's @ 4 ohms) will deliver the same amount of power to the subs , but when i add 2 more dcon's , 2 batteries , and show the fusion a final load of .5 ohms that car will really be slammin.
CLOSER TO 150 on 1/3 the power. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Not that i'm even breaking 145 , just sayin my ish is louder!!
So that's @ 4 ohms?
Late Update
went to the comp in Sanjose and got a best of 129.3 meca spl amature street3
I got a demo of the loudest ride in cali and everything on camera
lol yeah 20dbs... i have made some changes and found some issues so will se what happens and if i gain from the small changes ,i have built another box but i want to gain all i can before the change over
IMO, the box needs to be bigger with more port area. I hit 145 out the trunk on 2k with two 12's. box was 4.5 cubes and tuned to 34hz. 3.5 after displacment. You have a ton of space in the trunk left over. make a bigger box and fire port and subs at the back rear wall like 8 inchs away from the back wall. you should gain a good few dbs.
New update 136.4db i believe db drag race style
audio pipe --- well ill throw up a vid of some coaxial s that have my turned the other way .. the passenger speaker bass blocker exploded.
and is making a bunch of noise and my drier speaker actually burned out completely..after it was working fine .
i also had 2 audio pipe apsm amps and they are a no go clipped early i guess.. 1st one was to be a defected amp but when i got the second amp withe the same issue i knew it was the product.. no audiopipe for me i was actualy going to use there stuff originally but it all changed when i had no luck with the amps .
lilboom
Car stereo for fun
lilboom
ca
Bettr n' Revrse
