dross93ranger
I have the items below, I am willing to trade plus a little bit of cash if need be. I am looking for a 10" sub, preferable a 10" JL Audio W3 2 Ohm or Dual 4. I will also consider 8" and 6.5" Subs. I need something small, yet powerful for my wife's vehicle. I will also take trades for other car audio items such as components, door speakers, etc.
Everything works perfect, I just got a new amp and I need a 10" sub that will handle 300-500 RMS
Kenwood KAC-6401D
12" Polk Audio DXI D4 Sub
Pics and specs are below:
Kenwood KAC-6401D
Performance
RMS Power Output (Watts x Channels) 200 x 1
Peak Power Output (Watts x Channels) 600 x 1
Power at 2 Ohms (Watts x Channels) 300 x 1
Bridged Power (Watts x Channels) N/A
Minimum Impedance Bridged N/A
Minimum Impedance Unbridged 2
Best Frequency Response 20-200 Hz
THD at Rated RMS Power 1%
Signal to Noise Ratio 75 dB
Input Voltage 14.4v
Features
Amplifier Class D
Low-Pass Crossover Frequency 50-200 Hz
Low-Pass Slope (dB/octave) 12 dB/oct
High-Pass Crossover Frequency N/A
High-Pass Slope (dB/octave) N/A
Bass Boost No
Bass Boost Frequency N/A
Fan Cooled No
Fuse Rating 30 x 1
Speaker Level Inputs Harness
Preamp Outputs No
LED Power Indicator Yes
Width (inches) 7-7/8
Height (inches) 2-3/8
Depth (inches) 9-1/8
Size 12 -inch
Impedance 4 ohms
Cone Material Polymer Composite
Surround Material Butyl Rubber
Ideal Sealed Box Volume (cubic feet) 0.88
Ideal Ported Box Volume (cubic feet) 1.5
Port diameter (inches) 4
Port length (inches) 10
Free-Air No
Dual Voice Coil Yes
Sensitivity 88 dB at 1 watt
Frequency Response 27 - 200 Hz
RMS Power Range (Watts) 50-360
Peak Power Handling (Watts) 720
Top Mount Depth (inches) 6 1/16
Bottom Mount Depth (inches) 6 5/8
Cutout Diameter or Length (inches) 11
Vas (liters) 87.8
Fs (Hz) 30
Qts 0.5
Xmax (millimeters) 18.5
Kenwood KAC-6401D
Kenwood KAC-6401D
Performance
Input Voltage 14.4v
Features
Amplifier Class D
Bass Boost No
Fan Cooled No
Fuse Rating 30 x 1
Preamp Outputs No
Size 12 -inch
Impedance 4 ohms
Free-Air No
Dual Voice Coil Yes
Vas (liters) 87.8
Fs (Hz) 30
Qts 0.5
