WTT Sub For Wire, Distribution Block, 4x6" Speakers, etc...
dross93ranger
I am having trouble moving this sub so I have decided to trade it for some items that I need. What I need include:
4 Gauge Wire
Fuse Holders With Fuses
***Distribution Block with 1 4 Gauge Input and 2 8 Gauge Outputs and two fuses in it***
4x6" Speakers or components
6.5" Speakers or components
10" Sub
Other sizes of wire
2/4 Channel Amps
I am open to about anything as you can see.
12" Polk Audio DXI D4 Sub
Size 12 -inch
Impedance 4 ohms
Cone Material Polymer Composite
Surround Material Butyl Rubber
Ideal Sealed Box Volume (cubic feet) 0.88
Ideal Ported Box Volume (cubic feet) 1.5
Port diameter (inches) 4
Port length (inches) 10
Free-Air No
Dual Voice Coil Yes
Sensitivity 88 dB at 1 watt
Frequency Response 27 - 200 Hz
RMS Power Range (Watts) 50-360
Peak Power Handling (Watts) 720
Top Mount Depth (inches) 6 1/16
Bottom Mount Depth (inches) 6 5/8
Cutout Diameter or Length (inches) 11
Vas (liters) 87.8
Fs (Hz) 30
Qts 0.5
Xmax (millimeters) 18.5
need the cash but i owe you a good trade so give it a few days and ill let you know //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
Alright I understand that, I may have found some local so we will see. I'm going to try to get a small (VERY small dimension) 2 or 4 channel amp for it lol. I have like no room to install one, but need one. The only one I have (the Kenwood) is going in the van for that reason.
dross93ranger
dross93ranger
Maysville, KY
CAT MAN
