cotjones
hows it wrong? i looked up a definition...Wrong.
so resonance it what you get when you send energy into a tuning fork in the form of a vibration at a specific frequency..."In physics, resonance is the tendency of a system to oscillate at maximum amplitude at a certain frequency. This frequency is known as the system's resonance frequency (or resonant frequency). When damping is small, the resonance frequency is approximately equal to the natural frequency of the system, which is the frequency of free vibrations."
every object has resonance
i also found this...
hmmm... almost exacly what i guessed, //content.invisioncic.com/y282845/emoticons/crazy.gif.c13912c32de98515d3142759a824dae7.gif(without mentioning suspension compliance which i just took as a given and thus didn't mention)FsAlso called F0, measured in hertz (Hz). The frequency at which the combination of the moving mass and suspension compliance maximally reinforces cone motion. A more compliant suspension or a larger moving mass will cause a lower resonance frequency, and vice versa. Usually it is less efficient to produce output at frequencies below Fs, though motion below Fs can cause uncontrolled motion, mechanically endangering the driver. Woofers typically have an Fs in the range of 13–60 Hz. Midranges usually have an Fs in the range of 60–500 Hz and tweeters between 500 Hz and 4 kHz
