CRAZYCORNUTS18
Registered User
ok im planning on doing a sq system and was wondering wut would be the diff. of one sub off 300w, and 2 subs on 300w each?
y would it be louder its the same power just 2 subs instead of one? right2 subs running @ 300w each would be louder...
ur jokin right?y would it be louder its the same power just 2 subs instead of one? right
I dunno if he's asking about doubling the power. I think he's asking if it'd be louder with 1 sub @ 300watts vs. 2 subs @ 300watts.Isn't it 3 db louder? Double the sub & power? Heard that somewhere..... on here I believe. Probably wrong. Hrmmm
yes its totals 600w but not on one sub..so they way you say ,its that if you have 2 subs off 300 each it will just as loud as 1 sub on 600?Surface area would make it louder not to mention each on 300W with a total being 600W. Honestly if you are doing a true SQ setup I would go with one sub setup. Polo..
plz explain the reason behind this?Two subs on a 300 rms will be louder at a lower volume level. One sub on 600rms will be louder at a higher volume level. Polo..
