Hard to anticipate the rowdiness inside any cabin, Diy is always the best option. Sux you shelled out some bux initially and more to do it right.Jim's machine works: https://jims-machineworkx.myshopify.com/
made several parts for me. Most important thing they made for me was the bus bars for my battery banks. Very nice CNC aluminum blocks.
They fucked this part though.
These are the brackets at the end of my stripper pole. You can probably see why it failed. Those pieces that attach to the base plate were only welded at the bottom of the tabs. And poorly.
The broken one in the picture failed naturally. I tested the other one afterward by whacking it with a hammer. It bent lmao. Yeah, the metal pieces are 1/4" thick, I shouldn't be able to bend it with a normal hammer. The welds just stank. broke them by hammering to bend, prying back, hammering again a few times.
Very annoying because the part cost about $160. I shouldn't have to redo it myself. Removing the powder coat, breaking the pieces apart, welding everything...
And also sucks because now it has simple spray paint covering I did instead of the powder coat.
Just like my kids A/C... I was quoted condensers, evaps and compressors so I UV'd for leaks. Replaced the hi side service port and the overpressure fitting on the compressor to be thorough. $80 for a vacuum pump and gauges and another $70 in supplies and parts and those quotes of $700-$1500 disappeared. Lol... $150 later his Cobalt is ready for an Az summer this year. 36 degrees at the vents on a 90 degree day.
