Completed Shallow 10
From what I am seeing it would be a 3x3 aeroport for .9cu.ft
My Pioneer sub called for a 3x3.5 round. It was very noisy so I modified the box to sealed. Maybe an aeroport would have made a difference.
Maybe you should fabricate an enclosure of 0.9 cubes with that size aeroport for testing before modifying the vehicle specific box.
Does anyone know anything about BlackBrick subs?
BasketBlack Stamped
ConeNon-Pressed Paper
SurroundRubber
Coil2-Layer, 2" Flat Copper Heat Coil
SpiderTinsel Weave Leads on Red NOMEX
Motor40oz
OHMDual 4ohm
RMS300w RMS
Peak600w MAX
XMAX17mm peak-to-peak
QTS0.69 QTS
OMS5.68 OMS
QES0.79 QES
FS44.1 Hz
BL13.3
Freq Response44 Hz - 500Hz
Sensitivity86 dB
Net Weight7.6 lbs
Custom Box Specifications
Recommended Ported Volume0.74 - 1.16 ft 3
Recommended Sealed Volume0.53 - 0.88 ft 3
Tuning44.1 Hz
Port Area16 square inches per cubic foot
Cutout Diameter9.06"
Mounting Depth3.07"
Magnet Diameter7.8"
Total Height4.1"
Total Outside Diameter10.23"
Motor Depth1.5"
This has peaked my interest
$323 for a loaded fiberglass box? That's a smocking deal. It costs that much just for the materials. I'm tempted to go out and buy a Colorado just to have a reason to buy that box.
That's what I was saying when I mentioned it was a loaded box. Skars are decent subs.
Well I ordered it. Free shipping as well. To get just a sub enclosure from SubThump is
1 x​
*New* 2023 & UP Colorado/Canyon Crew Cab Large Single 10 Downfire Sub Box *New*
- Carpet Color: Charcoal Gray $0.00
- Speaker Openings: Single 10 inch Round Slim $0.00
$249.00​
Sub-Total:​
$249.00​
United Parcel Service Advanced (UPS Ground):​
$59.88​
Total:​
$308.88
I got the Skar for $322 plus tax shipped $347.21
AnthonyO
Budget Banger Connoisseur
AnthonyO
Minot, North Dakota, United States
michigan born
    May 14, 2026
michigan born
    May 14, 2026
