Should I do it?!?
  • 5
T2buff
I have two single voice coil 2ohm twelves running on a JP8 now. I want to get another JP8 and strap them together. But I'm nervous about the final ohm load the amps will see. Anybody think I should try it or just get a bigger amp 🤔
The resistance of the voice coils is the same and would be the same if another amp is added. Both amps together will still se the same load you have now as the voice coils haven't changed.
Yes, but when you strap amps each one "sees" half of the total impedance.
IMO if you can't afford to break amps and have to ask here you probably should avoid running any equipment outside of the manufacturer recommendations.
When you strap the JP amps they are spec'd for a 2 ohm load. Just run each amp separately to each sub for a final 1 ohm load on each. Make sure your speaker wires are the same length and you shouldn't have a problem. Those little amps are good for 1200rms+ at 1 ohm iirc.
The CT's are nice, That Sundown is a a frik'n beast!
550
2012 Nissan altima SR The trunk not ready to take back seats out I'm happy with the front and rear stage sub stage also I have a Sony DSX M80...
498
You can get close with tones, but music signal is all OVER the place in both frequencies and voltages. Like, if you listen to rap, the bass line...
588
Do you know what the box/port tuning is? And what is the db/octave slop on the crossovers being used? Setting the amp crossovers as open as...
909
T2buff
T2buff
Grimmjoww
    Apr 28, 2024
    Apr 28, 2024
