Different ohms on subwoofers.
Should I wire the 4omh to two ohm run that to its own channel. Then run the two ohm parallel to its own channel so they are both at 2 ohms or wire the two ohm to 4 ohm in series so it’s 4 ohms at the amp just like the other one. Ideally I’d like to wire them together to the box terminals and get rid of the second wire so I can bridge the two good channels at my amp. But sounds like I can’t do that.
For consistency, I would go the 6 ohm route. I'm guessing you can't afford to be risking a toasted amplifier by experimenting. Diagram coming shortly.
6 ohms is the least risk. I left the wires out of the picture for clarity. You would wire them the same as the ones shown.
Shit, man I’m sorry. I’m still confused. I see the bridge wire in the middle. The two wires going straight out to the +&— symbol what are those for? Can you finish the 6 ohm diagram?
You would bridge a positive and negative from the "outside" coils, just like is shown in the diagram, then run one wire from the remaining empty positive to your amp, then a wire from the remaining empty negative to your amp.
So the coils are fully connected in the middle? Neg pos to neg pos?
How much power am I going to loose? cause my amp is a 2-4 ohm amp.
The power you lose will be offset by the reduced risk of making the magic smoke come out of the amp for a second time.
If that amp is truly as powerful as they say, and the box is built properly, you should get it to deafening levels just fine.
Zachhunter
Zachhunter
Florida
