Metered the demo car šŸ˜¬
  • 6
djdilliodon!
759
NY
I donā€™t think most want to go through 11 pages on the original thread so Iā€™ll do a new thread for this. Little refresh, taramps smart 5k, 3.75 cubic feet each 15ā€ tuned to 31-32 hz. Subs at rest sit at 2 ohm so I know I ainā€™t seeing fully power. Car is at idle so voltage drops to 13.3 volts. Box was built outside the car and put in the back seat area, bolted down, and a top trim plate added to make it like a wall. Sides do have gaps about 4ā€ wide so itā€™s not totally sealed off from the trunk. Subs and amp I was playing for over 2 hours before metering so things are running a bit hot (will meter again when everything is nice and cool). The result? 150.6 on the glass @ 40 hz. Did get a 150.7 letting everything sit for 20 min and doing it again but didnā€™t take a pic. Now Iā€™m getting curious to see actual power the subs are seeing! I should of did the coils in D1 but ran out at the time as I was impatient šŸ˜‚. Wish I also made the box to 4.25 cubes per sub but would of required building the box inside the car and my old azz ainā€™t doing that šŸ˜‚. Iā€™ll get a truck next when this beater is toast!
I'm no meter guy but I think that's impressive. Especially firing from the truck. Will this be at slamfest?
not competing with this one, I use this car purely to give people demos locally before building them subs. If Iā€™m gonna compete Iā€™m doing a truck and thatā€™s next šŸ˜‚
That's all I'm going for. To give and receive demos
is it in Florida? Iā€™d love to go but wonā€™t have the time right now šŸ„ŗ. By the way this number is with everything closed (windows, doors, and sunroof). I already know with stuff open it will be louder and if measured in the kick. Iā€™m only interested in the glass measurements tho. I know I could squeeze more if I do a rebuild and lose a layer on the spider and use dual 1 ohm coils. The other option is use the bigger motors I have with Dual 1 ohm coils and some other tricks but I donā€™t wanna get crazy. I kept this build as cheap as possible so when itā€™s shown off it has more wow factor.
I guessed 53's @ 40 hz. on your other thread. Isn't there supposed to be a specific spot on the windshield for the meter? You might meter higher in that location. I think it's 12" from the a-pillar or something like that. 40 hz. is pretty good. Congratulations on the 50.
you hit the frequency right on the money! I believe itā€™s 12ā€ from passenger A pillar 4ā€ above the dash. Problem is the wire isnā€™t long enough šŸ˜‚. After the car sat over night I metered again with everything cooled down in 58 degree weather. Everything sealed up with meter on the glass and it pulled a 151.1 @ 40 hz. Ima gonna stuff blankets on the sides of the box next to do a quick temp seal off to the trunk and see if that gains anything.
New best score 151.3 and while I was driving šŸ¤« so voltage was at 13.9v. Then of course I couldnā€™t resist and did a burp with the meter in the kick, what a difference šŸ˜³. When I got home I did a a steady 40hz to and measure the load off the amp and itā€™s a steady 3.3 ohms. I wonder what a smart 5k does at 3.3 ohms and 13.9v šŸ¤”. My guess would be 3800-4000 watts. Anyone use the smd meter for wattage? Is the thing accurate?
New best! Everything nice and chilly since itā€™s 52 degrees out today, 151.6 @ 40hz on the glass. Did some illegal maneuvers measuring from the drivers side kick panel and lawd this car meters way better in the kick panel! Broke 154 šŸ˜³. For ish and giggles I was gonna stick the meter in the port but it donā€™t reach, itā€™s like a foot short the wire it comes with šŸ˜‚.
Didn't your meter come with a rechargeable power pack?
djdilliodon!
djdilliodon!
NY
hispls
DEW123
    May 7, 2024
DEW123
    May 7, 2024
