amp and sub matches that are good
i am wanting enough wattage up front and on rear doors, to fill out the sound with thumping those 2 10's, i know they have to have speakers with more than 200w for front and rear doors. i will have plenty of bass for now, i just like a full sound, more like the sweet spot in a concert venue where the music wraps around you and and you can hear all the instruments in your soul. lol
Your doors are a bit slim for the stock locations to get some really high output sound up there. Door pods are very helpful, and Dash mounted center staging works well that CDT has..universal A pillar mounts and or some tweeter pods will help also.. Maybe forming some Kicks with some nice mids also. There is a build on a Sentra I believe that may give you some ideas as well?
nice. i will see if i can look it up
what size inline fuse should i be using with these 2 amps. taramp says 150 max music and then a300. should i stay on the low side? i have no idea if the ct amp has a built in fuse. is there some kind of unwritten rule when matching fuses to amps?
I would do 300 ANL fuse from battery to a fused distro. block will be just fine on 0ga and 0ga ground Solid distro block is what i do.
Worth every bit of $10 bucks. XScorpian is made by Stinger
Nice little Fused distro block at the amplifiers I like
ANL Fuse Holder made by Xscorpian ANL4040P on Ebay for under the hood Sealed from weather is like $13bucks/ Platinum series. I dont know how to Screenshot on here for it. Amazon doesnt have it? ori coudnt find it.
On Ebay. Get two(have 1 extra) 300 regular sized ANL fuses for under the hood Fuse Holder. Two mini/midi anl fuses for Fused distro block,150 for the taramps and one for the 150.4(Recommended in the Maunal) mini/midi (Id grab 2 extra)also. be set for the power and grounding. one ground location on the vehicle to the ground block and from ground block to amps.
This wouldnt be a bad under the hood fuse holder with terminals and fuse for the Price
ebay in order to use links you have to use something like bitly to shorten the url and it will post okay audiobaun. The forum software that this site uses was updated about a year or so ago across the board and they stopped eBay links flat out as I use this forum software on a fantasty football league I am a commish on and admin on the site. Been using this software since it came out it has its positives and negatives and this is a negative. Because some of the bigger forums were complaining about bots posting links so it was one way to shut it down.
Thanks. I knew there was something a little different and had no idea the reason behind it. Thanks for the info
went ahead and ordered 2 of all the fuse holders and blocks. ordered 6 pack sets of the 300 and 150 fuses, plus 10 ft of ofc power and ground cable. i had another 0 gauge hook up kit but it doesnt say ofc so i just bought more, for the big 3. i have a skar kit here, so i will use that when everything gets here. i also ordered 2 of the fuse holders from gpaudio. so i should be good on wiring and fuses now.
what is the best type of terminals to use, so i can hook up all of the stuff from the car and still have room for all the stereo stuff?
can i go with a bigger odyssey battery than the 35? the one i the now which is just a regular battery has plenty of room in the cradle.
I use these to stack Ring terminals. You can get a longer bolt later on if needed at H.Depot or Lowes.these are cheap and work just fine for Post.Just make sure you get Brass,not Alumn or Lead
watcher6342
watcher6342
hortense ga.
Silicon oxide
