99 blazer fresh build.
Wolfram 2400.1
  • RMS Power @ 1 Ohm : 2,400 Watts x 1 Channel (14.4v)
  • RMS Power @ 2 Ohms : 1,300 Watts x 1 Channels (14.4v)
  • RMS Power @ 4 Ohms : 800 Watts x 1 Channels (14.4v)
  • RMS Power @ 2 Ohms (Linked) : 4,800 Watts x 1 Channel (14.4v)
  • Frequency Response : 10hz~200hz
  • Working Voltage : 8.5V-16V
  • Signal-to-Noise Ratio (Sensitivity) : >80dB
  • Low Level Input (Gain) : 5V - 150mV
  • Low Pass Filter : 20Hz - 200Hz
  • Bass Boost : 0 ~ 9 dB
  • Subsonic Filter : 10Hz - 50Hz
  • 2-Way Protection Circuitry Built-in (Thermal & Speaker Short)
  • LED Power & Protection Indicators
  • Master / Slave (Linkable) : Yes
  • Recommended Fuse Rating : 250 Amps
  • 1/0 Gauge Power and Ground Terminal Inputs
Wolfram 2400.1
looks promising, do you have personal experience with them? From what I’ve read briefly they do rated power plus some and are solidly built. Found a refurbished one for $249. Which is not bad.
IanRowb
IanRowb
Medford, OR
IanRowb
