How loud is your system?
Do you guys think I'd see a big difference if I moved my batteries and amps to the way back and slid my box forward 10 inches?
Have you metered it outlaw style? Does it gain quite a bit door open?
I gain about 2 db when I open a door. Haven't tried a window. I definitely can hear and feel the difference. And I like to listen to the music with the sunroof open or a window open cuz I can feel more airflow
hitting at 25 - 35 hz,
What sort of music do you use where you need to play so low?
Numbers seem a bit shy of where you could be with that but the box seems to play rather flat and probably sounds good with music.
If your goal is to play lower you must rebuild your port or box to tune lower. You may or may not be happy with the rest of your frequency response after you do so.
Deon1818
Deon1818
MN
Slo_Ride
