Hardworkingman32
1). Do you recommend starting a new configuration with the eq set to flat, super bass, powerful, or a smiling eq? The head unit is a pioneer 6800BS. It defaults to powerful mode even when I do a system reset on the headunit.
2). What do you recommend setting the LPF at for a subwoofer which has a frequency range of 34hz-250hz. The subwoofer is in a sealed box that is primarily used for listening to rap. I am looking for as much bass as possible while trying to remain distortion free. The sub itself is a Punch 12" P3S Shallow 4-Ohm DVC Subwoofer | Rockford Fosgate ®
3). What should the ISF be set to on the amp for listening to rap music. The sub itself is in a sealed box with 0.84 airspace.
4). What +-DB should the bass test tone be when configuring the setup for rap music?
5). What octave roll off is recommended to maximize the bass when listening to rap music -6 or -24 octave? What exactly is the difference
6.1). Should I keep LPF turned off on the headunit or match it to what the subwoofer amp is set to?
6.2). Should I leave all of LPF and HPF turned off on the headunit if LPF is set on the amp itself.
7). If my amp has an LPF at 80 what should my HPF be set to and what roll off octave to do you recommend for HPF with rap music?
8). Should I use loudness at all? It offers four settings low, mid, high, and off.
9). Should I have bass boost on at all?
10). Is it okay to have SLA maxed out at +4? The bass seems to hit just a little bit harder when its turned up. Does this setting cause alot of distortion?
