New sub help
It is a Power Acoustik R1500.1D. Only issue with the 2 ohm is it pushed 900 watts at 2, and the sub is a 600 watt RMS.
When all is connected, turn the GAIN all the way to 2V or higher. Turn on the system, then turn up the radio to the highest volume you listen to it, with the best bass line song you have. Now turn the GAIN to the opposite of 2V until you are comfortable with how the sub is hitting. Done. If the bass is not enough for your other songs, you could adjust a bit, just mind the heavy bass songs.
tornadobob
Junior Member
tornadobob
IN
