Areo or slot
Because he has significantly more experience and just asked the question. And a valid question since that is on the high side and can get into mechanical trouble. You'll notice OP tried less airspace, wasn't happy and was happy with them in 6 cube each. All things being equal he will gain output and efficiency going up to 7 cube provided he isn't at the mechanical limits of his subs.
Build more boxes, test every variable you can think of, buy a meter and take measurements, lurk more.
[/QUOTE]
Did you even read my first post to the OP? Probably not. What exactly did I say wrong? I actually asked him three questions. I don't understand why people wanna throw shade.
My last box was 7 cf per woofer with a slotted port almost blew the front window out...I've always put my woofers in bigger boxes and have never had a problem. Trial and error if it doesn't work I will build a new box...its just my hobby
Good luck with that fart box. Either output limited with 50in2 if port or oversized till its tapping + port limits, Either way its yours. And Bobbyjackass's.
2 15s is bad enough... 4 15s just no.
I jUsT bUiLd BoXeS
I said 3- 15's in a fourth order blow through and replace the amps. Get it straight Valley of the Sun boy.
Why is homeboy hsy
Obviously you and Bobby have a connection and have been Pming ea other. Let him figure it out. I'm sure your disaster will be improved.
Eventually.
You sound like a hater .instead of being negative why not pass some knowledge since you know all...your a master builder apparently
27959
Ok man... this is what kills me. Sent to Bobbyjackass like he's an authority and you acting like a pro.
This forum is is shit show anymore, how about taking criticism like an adult? Bobby sure cant.
That thing had to be limiting output/maybe chuffing and def cancelling all the way to an epic fail... but ok.
Its your ride.
I could do 4 15s ez in that space, Others could too. Think about that
Eventually.
Hey man, honestly, why wouldn't this aeroport setup work? I'm trying to learn this shit the best that I can. We were installing until 5:30 this morning on a car that had to get done. I figured that 2-10" ports would give him just under 12 in2 per cube. Is that bad?
Caliboy916
Caliboy916
California
Firewalker
