New system setup
  • 5
Hogan1998
I have a 2004 Toyota Tacoma 3.4L v6. I’m wanting to run 45000 watts rms. Subs are 2 skar vxf 12s. Amps are skar rp4500.1d and Skar rp75.4 4 channel amp. Will 1/0 wire be sufficient? What size alternator do I need? Will 2 Xs power d3100s be enough power for my system? Thanks
I have a 2004 Toyota Tacoma 3.4L v6. I’m wanting to run 4500 watts rms. Subs are 2 skar vxf 12s. Amps are skar rp4500.1d and Skar rp75.4 4 channel amp. Will 1/0 wire be sufficient? What size alternator do I need? Will 2 Xs power d3100s be enough power for my system? Thanks
The skar rp4500.1d has one 1/0 power terminal and one 1/0 ground terminal. Your probably thinking of the skar skv24500.1 which has dual 1/0 power and ground terminals.
Yes and No. Amp recommends that size but that particular version only has 1 terminal. Weird to have 1 terminal for 250-300A grade power wire but then directly advertise that the amp has an internal 450A fuse ? (I guess skar figures if your buying a budget amp your never going to spend 2000+ dollars on electrical upgrades)
DC, Singer, and Mechman are the brands you should be eyeballing. This is an example of one DC makes for your particular car
In regards to size depends on what you actually want to accomplish, what the companies actually make for your vechicle, and what can you realistically afford. Most of these aftermarket alts are anywhere from like 200A to 370A range.
I would start with aftermarket alt, a really good XS battery under the hood, and big 3. From that point you can monitor usage/voltage and see if more batteries are even needed
Thank you
Thank you
19
566
663
that is an Ideal crossover and designed for use in an home type loudspeaker. A simple Linkwitz-riley 2-way is easy enough/ The tweeter wire lead...
36
Hogan1998
Hogan1998
Louisiana
Hogan1998
GoldCountryCA
    Apr 26, 2024
GoldCountryCA
    Apr 26, 2024
