Computer building, I am
Case swap done. Turned out good. Just gotta order my CPU cooler and a few more ARGB fans. Going to run some games to see what the temp difference is now with a good flowing case.
bout time you actually did something worth a like post specs sir and what do you plan on doing as far as cable management and are you gonna add any lighting to the inside of the case to show off gpu and such
is that a xbox i see next to a computer? dude you just threw yourself back like 40 years with that combo a pc is every playstation and every xbox that has came and will come out......you bout a twisted thinking **** up huh
Once a program shuts off, my CPU temps always go back down into the 30C range immediately. The AIO is set up on a factory auto curve so it's only like 800 RPM at idle. It seems to not go past 60-65C so far, so I bet that's when that AIO starts really spinning up like a madman. I think it does 2800 RPM unless it goes into to overheating where it'll do 3500 to save the CPU. I'm probably gonna run the Ryzen Master all the time and just check up on temps as I go along, until I trust what I built and get used to it.
I've got my fans set up better, got all my box design stuff transferred over.
If anyone is interesting about a backing up service, thanks to @Coolhand20th for helping me find this with their partition manager, there's a backup service called AOMEI Backupper. I do a sync where it literally copied my laptop's SSD directly onto a flashdrive, where the flashdrive exactly is sync'd to my laptop's C drive (main hard drive). And it's free
Buck
little alien on campus
Buck
Inside of a pyramid
ThxOne
BP1Fanatic
    Jul 1, 2026
BP1Fanatic
    Jul 1, 2026
