Battery recommendations
  • 6
  • Participants list
I'm planning a complete overhaul of my power in my car and the last thing I need is a battery. I have a 900watt rms 3800watt max system and was hoping for 80+ah. Does anyone have any cheap alternatives to xs power I'm trying to be under $300
I just picked up a die hard agm from advance auto this past weekend. That plus I upgraded my Big 3 with ofc wire. Seems to be doing the job so far.
What size underhood can you fit? Is there any room in the back for an auxiliary as well? I as well upgraded to diehard agm, then put lithium in the back. Titan 8 pwr-s5
According to AutoZone I can fit a group 35 and while I do have room for a battery in the trunk I'm trying to get away with just the one under the hood
Do you also monitor voltage at your amp(s)? it’s very helpful, I had my 160a alternator modified into a 326a locally here in Denver, it now does 14.5-14.8 at idle
Only gauge I have is a cigarette lighter one, but when I still had a cap I tested it again it and they had the same readouts
I was really happy adding an agm just before my smart 3, helped tremendously
I'm not an expert on Lithium by any means. All I can say is I've played my system for about 2 hours at about half volume(20/36 on the headunit)...
What the ****? Are you trying to put ohm's law into very complicated verbiage?
862
I like the way these look. But whatever I do it has to be top post. My battery is on the driver side and right beside the air filter housing. So...
621
Loud(ish)_Geo
Loud(ish)_Geo
Pennsylvania
JakeW
    Mar 27, 2024
Daniel Lee
    Mar 27, 2024
