Alpine X 12" Enclosure Recommendations
It’s wired at 2 ohms. This is the box. It’s my first carpeting job so don’t bash me. And I have it pushed against the rear seat.
I think the port is too small. Again, I know you followed Alpines specs but I just don’t think that’s good enough for the sub. I think the box build looks good by the way
I would do 3 cubes at 28 hz with the type X. The w6 is more efficient ported than the type x, in terms of box size. That x wants to be in a big box tuned super low, with lots of port area. 40 sq inches or so. my opinion.
Good thing I have the trunk space. I may try this. I listen to mainly hip hop and I want to hear and FEEL the bass so this should do the trick you think?
Rear firing means the sub is facing the trunk. Forward firing means it’s facing the front of the car. I find rear firing in trunks works best
I was responding to THATpurpleKUSH when he stated "Port needs to rear fire." So... I assumed he meant the port should fire out the rear of the box while the sub is facing the rear of the car. So you're saying the sub AND port should be on the front of the box firing to the rear of the car?
Marve_Lous
That Guy
Marve_Lous
Houston, TX
Jeffdachef
