MKIII7
I'm new to the forums and to car audio and I am looking to do a small set for my car. Its a 2020 Honda CR-V Touring edition. I'm looking to do a 5 channel amp and run everything off one amp. Also going to run two 10" or 12" shallow subwoofers in a sealed enclosure that's 1ft3 net volume per woofer ( 2ft3 total). I'm looking at either getting the Rockford Fosgate T1000X5AD or the Digital Designs D5.1500. Wanted your guys input on how theses amps are. The front channels are not too different as one does 100x4 and the other does 125x4. The main difference is the sub stage. The Rockford does 600RMS at 1ohm and the DD Audio does 680 @ 4ohms, 1000 @ 2 ohms, and 1500 @ 1 ohm.
If I go with the Rockford amp I was thinking of getting two 10" or 12" JL Audio TW3 at 1 ohm so thats 300RMS per woofer in a sealed box 1ft3 per woofer.
If I go with the DD Audio amp was thinking of getting two 10" or 12" Sundown Audio SD-4 either at 1 or 2 ohms and in a sealed box 1ft3 per woofer.
