Are Entry-Level DSPs Any Good?
Settle down, you're talking to someone who has hands on experience with likely nearly every programmable DSP sold currently.
Oh my bad did I initially quote one of your responses? Grown ups can respond for themselves. Never commented on his expertise with dsp and don’t doubt it. Simply stated his long ass pontification didn’t bring additional insight or address op’s concerns/ask/current gear.
Prior responses advised ditching the passives, move each front separate to the four channel, and ditching the coaxials (he’s got the jl 4 channel and spending $$ on another amp for the sake of connecting rear 2 ways isn’t going to improve his sound)
go ahead...please advocate that getting a dsp and staying on passive crossovers in his scenario (or any scenario) makes sense.
what vehicle?
how do you have it all setup now? xover points, slopes etc? and where did you install the tweets etc? how did you set your amp gains? you runnin the mains active off the deck or amp or passive off the JL xovers?
using any sound deadener?
Thank you, I will. Remember that a typical programmable DSP offers a set of tools. Channel level controls, delays, individual channel EQ, polarity control, altogether surpass what nearly every aftermarket head unit has to offer. Considering how often the head unit is no longer replaced a DSP is even more useful to achieve better tonality and improved imaging, regardless of the presence of passive crossovers.
Dude! Surely your not this committed to your stance for the sake of being stubborn. You’ve twice now missed content op provided in his post. He has an aftermarket unit...with good signal....the tuning and filtering capability is lacking on his model. He gets a dsp gains better tuneability and increases output where it counts by putting the crossover on the shelf and moving four channels of amplified power to the front.
So let me get this straight.. you dont think its worth it for him to get a DSP unless he ditches his passive crossovers?
Factory. 2021 Chevy Silverado custom trailboss
556
Use two sets of RCAs. One set for the Front channels and the other for Sub Output and into Rear Input on the amp. Turn off the Rear Filter on the...
661
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
581
I came across those too. Seen all the drivers out on the alibaba sight for sure. Wonder who is making them for PPI? Looked long and hard at those...
28
Ruggie74
Ruggie74
Abbotsford, BC, Canada
BCotrell
    May 16, 2024
    May 16, 2024
