- Thread Starter
- #31
Amperage draw is the result of impedance and wattage. If you run the single woofer at the same power levels as the two you have now the Amperage draw will be the same.
will be running on the same amp so yeah power will be the same. Just annoying the bass keeps cutting out when turned up loud. Cuts out cuts back in, strange though as it doesn’t cut out so much on the powerful loud low notes it’s more the higher notes it cuts out on.
