Design Question SA 12" LCS 3.5ft^3 @32hz
Ripkon
Vehicle : Crown Victoria
Location in the vehicle: Trunk
Space available (Length x Width x Height): 36x22x18
Subwoofer make and model: Sundown LCS
Subwoofer Size:12
Number of Subwoofers:2
Type of Port (Kerfed, Slot, Aero, etc.): Slot
What type of music do you like?: Hip-Hop
Is your goal SPL or Everyday Music?: Loud boom
Tuning Freq (Hz): 32
Volume :
Hello, im trying to build my first real tuned box. Speakers are Sundown LCS. They recommend 1.75ft^3 per sub and tuned to 32hz. Speaker displacement is .12. I have been reading for days learning as much as i can. Im wanting to build an enclosure that has the port in the center with the L on each side (also 45 the corners in the back). Speakers are rated for 300w RMS, but i will most likely run 800w RMS @ 1ohm. I have used the box building calculator some - i haven't tried winISD yet. Here is what ive came up with so far - am i heading in the right direction?
Also here is what im going for look wise (without the center brace)
Build it right... don't leave out parts, deaden the car like discussed, set your levels right, Ssf accordingly and enjoy... your welcome.
Glad to assist
I had two lcs 12s in a ported box. It was a prefab that was 1.75c per woofer and it sucked... they needed a wayyy bigger box forsure. Space makes bass yooo
Ripkon
Ripkon
Virginia
Ripkon
