How long will it last?
All mocked-up checking fit, only a tiny bit of trimming before slapping it together.
The process is becoming far more involved than a standard ported... shit... I had to figure out the best way to pre-assemble the thing so it goes together easily.
That's an interesting enclosure.
it's 13ft3 externally
Btw I have painted mdf before. It takes some primer 1st, maybe 2-4 coats since mdf soaks up like a sponge then paint.
Better buy a buncha paint huh? I plan to do 4 at once eventually the 3.8ft3, 5.75ft3, 9ft3 and this one... I'll never be able to sell those extras otherwise
At least I'll have plenty of practice
You have just under 35sqft of surface area, a quart of primer and a quart of top coat is all you need. If you use a dark topcoat get the primer tinted with some black pigment, it will help the topcoat cover better. It's important to use a shellac based primer because those will seal a porous surface the best.
Done... serious pita building this thing
146 lb with driver... I'm reserving a hospital room now for when I throw out my back...  :wow:
I made the top removable so I can access the sub, possibly add windows on top, and add interior paint later... maybe some lighting inside too?
But for now I'm focused on hearing the thing. I'll finish out and paint it later
Next time I paint a box I am avoiding cans.  Was a good learning moment though, but I am not a master at rattle cans.  I used both on my last box (can and brush) but I think I need to be more selective on the type of primer/sealer and paint I use...
What kind of gasket material was that you used for in between the top sheet?
Cheap 3/8" x 3/16" foam weatherstripping, with some silicone underneath to adhere to, worked pretty good imo,... I had to really bar clamp it down (3 at once) to close the gap as much as possible, once the edges were sucked down along an edge, I ran the screws in and repeated till it was tight all the way around... then went around the whole thing again and got it even tighter.
#8 2 1/4" coarse to pull the center down where the double baffle is and #6 1 5/8" coarse everywhere else. It was a long process.
It's in and sounds great.
Out with this monster
and back in with another... lol
still adjusting the filters but I've missed that under 30hz stuff apparently... I just had the dash jumping a bit... 😁
shredder2
CarAudio.com VIP
shredder2
Az
shredder2
vegang
    Jul 1, 2026
vegang
    Jul 1, 2026
