tweeters off h/u?
All of the following is common sense stuff, but I just wanted to give the friendly public service announcement.
  • Just make sure the tweeters aren't providing an ohm load that's below the minimum of the HU (e.g- 2 ohms tweeters on a 4 ohm minimum HU). Not that 2 ohm tweeters are flooding the market.....
  • If you're going to run them directly off the HU (without the passive xo), make sure the HU's HPF can be adjusted appropriately as to not allow the tweeters to play frequencies that are too low for them.
  • Keep in mind that most HU's exhibit around 5% or more THD when outputting max RMS. That level of distortion can usually cause negative effects.
cool,thanks for the info man
I did an adire koda 8 for now but I'm considering swapping it to a Dayton ho 10. More cone area for more midbass. But I might not need to. I might...
16
You can Email or Call GP Audio and they can make some adjustments to make the enclosure shorter and either deeper or longer on the Glue and screw...
114
8K
I had this same issue with my Sony. When I first got it I had speakers hooked up to the head unit without amplifiers and it worked fine. Once I...
Ridinhi
Ridinhi
Winston-Salem, NC
DejaWiz
GoldCountryCA
    Apr 26, 2024
GoldCountryCA
    Apr 26, 2024
