WTF... my system won't work :(
i'm not quite sure what the other guy was trying to say, but if your asking which wire is the remote wire on your head unit? usually a blue wire and you can connect a toggle switch to that if you want so you can control the power going to your amplifier
Do I see a power wire NOT going through a firewall, but going through your car door/corner of your hood?
and your remote turn-on to the fusebox under your dash?
I.. don't really know what to say.
ya ur car door could cut tha power wire and ground everything out
blowing amps not good
ya your head unit manual will have a diagram of your harness
but the remote wire is almost always blue or blue with a whit stripe
i used to have one of these amp it was doin the same shit
it turned out to be a bad ground(my kx2500 worked off that ground)
i dont know what it is they thinks there strong enough to be grounded to the batt
Popez
Popez
Minneapolis, MN
pitbull419
