Woofer Wiring - my **** gonna catch fire n burn?
WOT
Banned
Sorry for the catchy title lol, just finished wiring up 4 DVC 4ohm woofers HOPEFULLY down to 2 ohms.
I used this guide
http://www.rockfordfosgate.com/rftech/woofer_wizard.asp?submitted=true&woofer_qty=4&woofer_imp=4
So I basically took a positive and a neg on each sub and twisted them together. And then connected all 4 left over positives together, and then all 4 remaining negatives together and running single wire from each to the amp.
Havent fired it yet.
Heres why. When I said I connected a POS and NEG on each sub at the start, I simply grabbed a POS coming form th top of the sub, and a NEG coming from the bottom of the sub to do this. Was hoping it didnt have to be more specific as long as the came from opposite sides of the subs.
Hard to explain. Hope someone can lmk if its ok to use it this way.
Thanks
ummm...the diagram is pretty self-explanatory. you either have it that way or not. what is your question?
Well there are 2 positive and 2 negative per sub, I dont know if it matterred WHICH pos and neg I wired together.........
if you're wanting 2 ohm...all positives need to be together. All negatives need to be together. You shouldn't have ANY pos to neg connections on your subs.
Very confusing way to explain. Let me try to answer your question.
You said you took a + from a random side and connected to a - on the other side. When you do this, you should only have a + or - left on each sub, so connecting all positives and all negatives is fool proof.... i hope lol
You need to series the coils to get 8 ohms per driver then parallel them all for 2 ohms...
so you need a pos on one coil to a neg on another coil.. then all positives left over together and all negatives left over together
OK ya so I did it just fine then, I didnt knowif it mattered WHICH pos and neg were together, as long as they were on opposite sides I did it.
Im almost done this install, only have to tighten the ground, mount a dist block , and since Im out of 0 gauge Im gonna be running 3 4gauge wires for power about 30" long...... til monday, cause im anxious to power this visonik 4000D up lol
that is an Ideal crossover and designed for use in an home type loudspeaker. A simple Linkwitz-riley 2-way is easy enough/ The tweeter wire lead...
36
Those subs are 400w RMS each, and that dual enclosure is 800w RMS with a 2ohm load. That's a 4ch amp that does 55w x 4 @ 4ohm, & 75w x 4 @ 2ohm...
873
  • Locked
Looks familiar: https://www.caraudio.com/threads/who-needs-new-equipment.613325/ Wouldn't that be a real kick in the ass. I shared that so...
And dont skimp on the Sql...that doesnt mean it dont get loud,that just means it sounds great while getting loud lol
Well yes, I've searched cruthfield many times, I just wanted input from actual people to go off of instead of numbers and prices. I've got it...
WOT
Banned
WOT
Toronto,CANADA
MisterGrubbs
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
