Wondering about sub choice
flea77
Lets start with where the system is headed. Eventually these will be in the vehicle (2007 Buick Lucerne):
Kenwood DNX6960
Polk MM651 fronts
Polk MM691 rears
For the sub I currently have (pulled from my old car):
Kenwood KAC-529S 120wx1 amp
MTX Thunder 6000 12" sub
Off the shelf enclosure
This car I am doing a little different, I am more geared towards quality than quantity. One other concern is space, I need as small as possible. In my old car the MTX with Kenwood did fine although it could have been tighter.
What I am wondering is should I keep the 12", replace it with something like a nice Polk MM1240, ditch all that and go with a pair of 8" MM840s? What do you think? I am primarily concerned with tight, clean, low bass that will probably never be heard outside the vehicle.
Any thoughts appreciated!
Allan
I don't think I really need an amp more than what I already have for what I am trying to accomplish. The setup I already have is more than "loud" enough. I mainly want better quality sound, and if possible, a smaller space taken up. As for budget, I would not mind spending a few hundred on a sub.
Allan
Allan
so how much does your amp produce? as in how much was your previous sub getting
Kenwood Mac-529s, 120watts bridged into one 4 ohm 12" sub.
I was thinking the 12" Polk would be a better sounding sub and I think it requires a smaller enclosure which is two good things. I also thought about a pair of 8" as that might be slightly smaller than what I have and probably tighter, but I might loose some of the lower end.
Torn and confused.
Allan
Torn and confused.
Allan
Well dang, 120 watts aint nothin to us lol.
But like i said earlier, dayton reference
Yes, I know, years ago been there done that, dual 15"s in a small car with 800 watts at 2ohms. Don't want to go there again.
So you think Dayton reference over Polk? And one 12 or two 8s?
Allan
Allan
120 watts for 2 8s? Not necassary. One 12 will be fine.
flea77
flea77
Huntsville, Tx
09civic
NorthFramingham
    Jun 30, 2026
