Wiring up 3 ohm components.......
  • 2
DJ FURY
US
I was thinking about running a set or 2 of boston acoustic pro series components.My question is how can i wire them up to my 4 channel amp since they are 3 ohms?ill start off with one set but ill eventually get the sec.can i wire up the one set or do i need them.Just figured id ask since i have no experience with 3 ohm voice coils.
wiring a speaker to each channel will give u 4 3ohm loads and since most amps are stable atleast to 2ohms, you should be fine, the amp will produce about half way in between the power of 2 and 4 ohms
doesn't matter, if you just get 1 set first then you will only be using 2 channels of the amp (same ohm loads) and if you get 2 sets then you will be using all four channels
So no matter what my 4 channel will have no problem with these 3 ohm components?What do u think of these components?No matter if i start out with one set or not i should eb ok?
Hello I'm happy to have came across this forum as I'm hoping someone will help with this little bit of confusion I'm having and maybe save me some...
Deff need to lnow what subs.. Make and Model# would help quite a bit. What amplifier will you be using?
88
360
353
DJ FURY
DJ FURY
US
Acidburn
    May 16, 2024
    May 16, 2024
