Wiring under 1 ohm
That current box looks like a prefab to me, here's one I did a design for recently for with a 1200 watt amp pushing the subs...
IDK what your goals are but the port area you got looks a little small to me for one thing.
Ya, Type S subs believe it or not in the right enclosure will rattle a trunk real well given a good amount of power, and battery reserve. Instead of investing in a third sub I would invest in doing up a proper box for the two you have and use the difference in a better amp, more power etc.
Well the price you are going to put into a 3rd subwoofer would pay for wood and screws to build a proper box...  BTW how are you going to wire 3 D4s to .7?
All my SA's read 3.7ish.. ending up right at .625.
Maybe other coils are different, i never played with anything other that Sundown after i got back into the hobby
I recommend OFC all day long. You can even pull it later on and use it again if need be with little to No Corrosion. Run Power wire from battery...
27
176
Box rise, more accurately, impedance rise, is the reactive load changes the woofer exhibits at different frequencies and it will happen, it's...
425
thanks 1aespinoza for advice I decided to not use the blaupunk I got a real nice Pioneer.
338
jaydencoe
jaydencoe
Lansing MI
poolman966554
