wiring trunk battery to alt
  • 5
Polski13
MI
I already have the big three taken care of for my H/O alt and I want to run 1/0 from the positive on my alt to the positive on my battery in the trunk if my car. Is this ok to do? Will it benefit my system and car? Or will it screw things up?
Yea its OK to do. How many amps is alt?
Well technically, you want to run it from the alt to a fuse near-by then to a fuse in the trunk, then to the battery. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
^What he said, my bad! Too early lol
Ok ill use two 300 amp fuses. I was kind of planning on that but wasn't sure what size to use exactly
Use 1/0 wire and a 300a fuse (x2). That is what I would do.
Curious, why 2? I wanna learnt good //content.invisioncic.com/y282845/emoticons/nerd.gif.c6fa51ddf7ff75f1c0371fbc648f70ae.gif
You want one at the front, and one at the rear. Basically to isolate the wire in case something stupid happens. Say the wire grounds out to the firewall. The fuses would pop rather than the wire burning up. Standard procedure with a long run IMO. Especially between batteries, or in this case alt and battery.
Extra protection on both ends ...curious as to why run from the alt to the back batteries ?? not sure the gainover running from front battery to bacl batts
Aha! Makes sense, thanks.
I would guess he's isolating backups from front batt? Not sure, guess it'll be more direct? Instead of having the front battery as middle man. IDK Ive never done it that way.
Good question. If there is a front battery, then you will want to go there with that alt cable. Why send that power all the way across that wire to the back? Take the long run and go from that same fuse you were going to use for the alt and go right to the front battery. Then from the alt to the front battery (with or without a fuse on that wire). The fuse in the trunk before the rear battery still needs to be there though.
Does that make any sense?
I was just wondering why he was wanting to go from alt to back batts if there was a front batt??.. jus go from front to back
Maybe he isn't running a battery up front. Could be a few reasons why, but I ran mine without a front until last week. The wiring is the same though. I just isolated/insulated the POS terminal for the front battery while it was out.
The wiring harness adapter is less than $10 online. It makes everything 10x easier. You just wire your new stereo to the adapter outside of the...
282
Ive doubled up 12 ga many times for sub wiring.. even 14 ga for speaker wiring. Its OFC and it should do great and save you some money since you...
673
My brain hurts just looking at those diagrams. It's late so if anyone sees a problem with either of those, please feel free to chime in!
693
693
595
Polski13
Polski13
MI
Polski13
