Wiring Subs - Questions I have
  • 6
Dang, ok. I didn't really want to wire up another power cable lol, the car is a pain in the butt to run the cable :D ty for the info :) I work at a parts store so I can get a discount on an AGM battery, and my alternator is pretty new also.
You shouldn't need any big 3 for that amp your electrical is in good shape, it really doesn't pull that much power. Yes, run 4 gauge. I also had to switch from 8 to 4 when I installed the amp. Mimes run under the carpet, so I taped the 4 to the end of the 8, and pulled it through. This made it easy to run the new wire.
I don't mean to take over this thread, but I've seen people say this often.
When doing runs between batteries and alt to battery, I understand this because you're protecting the wire, not the equipment. But when you're fusing specifically for an amp, isn't that to protect the equipment (the amp)? So wouldn't you just use the recommendation of the manufacturer or whatever the math equals to as far as wattage output?
Not trying to say your wrong, please don't take it that way, just curious
Current is PULLED BY the amp, not PUSHED TO the amp. If the current going to the amp is excessively high, it is due to an issue with the amp itself overdrawing, meaning your amp is already broken or you wired it too low. The fuse in the power wire will open the circuit if the amp pulls too much current or if the power wire gets shorted to prevent the wire from heating up and causing a fire. Built in fuses primarily protect the amp from wiring mistakes. I can't think of any scenario where a properly wired/loaded/functioning amp will suddenly pull an excessive amount of current and having a fuse in your power wire will protect it.
Wire to the 2ohm diagram as shown for the MTX subs on the one amplifier you have. That amp should do very well on those two subs. alpine make some...
No not in this situation.PM sent for proper use of the Y splitters for this situation
34
5K
Sure, 600 volts, yep. If you’re trying to launch the subwoofer cones to the moon! And, that’s if they don’t just vaporize first!
34
4K
Sell the dual 2 and get another dual 4.
ButtButt
ButtButt
Nebraska
just call me KeV
    May 1, 2024
just call me KeV
    May 1, 2024
