wiring needed
is this all i need in total for two subs, 4 door speakers, 2 amps100ft of 10ga (which ill use when i get my subs thats why im just buying alot of 10 and not 12)
(2x) 8ga amp wiring kit http://www.knukonceptz.com/productDetail.cfm?prodID=KOLAK84
1/0 to the trunk
distroblock
and the kit comes with rca's
150amp fuse
do i need side battery terminal things?
does the distroblock to amp and then for mp groudns have to be 4ga? or will 8ga work?
You only need side terminal conversion bolts if your stock wiring/ wiring can't reach the top of the batt. But it is a good idea to get some ring terminals, you can't hook up an amp to a battery without them. The ground wire should always be the same size or greater than the power wire.
k. ill use 4ga then.
on my rca's it says This 5 Meter (16.5ft) RCA cable also has a built in remote turn on lead. so i dont need a remote start to my HU this is build in to the rca's?
and what all adapters and stuff like that do i need. i have this so far
KonFUSED 2 Way Digital Distribution System (150A,150A)
Silver Plated 150 Amp ANL Fuse
KLMX Kable 1/0 Metallic Blue Power / Ground Cable
Klear Kable Blue 10 Gauge Speaker Wire - 100Ft
Klarity 2 Channel RCA Kable 5M
Negative Battery Terminal
Positive Battery Terminal
KLMX Kable 4 Gauge Metallic Blue Power/Ground Cable
for the dist block, what fuse sizes should i get? (im guessing the fuses go between the amp and the distroblock)
taintedplay
taintedplay
dallas
taintedplay
Old_risk
    Jun 23, 2026
Old_risk
    Jun 23, 2026
