When you use Series or parrallell, its so you can make different subs different ohms, lets say you had 2 4ohm dual voice coil subs, and you had a 1 ohm stable amp..
If you wired the subs in parrallell, you would make the amp see 1ohm
ohms are resistance, the higher the resistance (ohms) the less power
