wiring needed
componet amp: '08 HIFONICS TXI6408 680W A/B CLASS 2/3/4CH AMP NEW -
sub amp: HIFONICS TXI1008D CAR AUDIO 1000W CLASS D AMPLIFIER -
sub 2x Alpine SWR-1242D type r
head unit: PIONEER DEH-P4000UB CAR AUDIO/STEREO CD/MP3 PLAYER 4000 -
speakers
Polk Audio db571 back
Pioneer TS-A6872R front
your gonna need to run 0g to the back and put a distroblock on it and run 4g into the amps.
my fuse holder wonthelp. and my 8g is only applicable in your setup for the sub wiring...
but anyway, those are the things you nee.
you also need a 0g fuse holder with about a 150aish fuse
so i need 0g to the trunk, then 4g to both amps. On the 0g to the trunk i need a 0g fuse holder with 150a fuse. what about wiring to the speakers, subs, all that? i have no wiring at all at the moment except wiring harness
ok, let me see if i can get all of this...
you need enough 12 g wire to run from your door speakers to your component amp
you need enough 8-10 g wire to wire your subs to your sub amp
you need a run of 1/0 g wire to the trunk
you need a distro block to split it into 2 2 or 4 gauge power wires
you need enough 4 gauge to run your grounds and from the distro block
i think i got it all
on the 12g wires to speakers from comp amp, dont i need twice the distance? for two wires to each comp? (im guessing + and -)
and same for subs to sub amp
then 2 or 4 gauge from the distroblock to power the amp
and the fuse (150a) would go between the distroblock and the battery?
on the 12g wires to speakers from comp amp, dont i need twice the distance? for two wires to each comp? (im guessing + and -)and same for subs to sub amp
most speakerwires that size come connected as a pair, if not then yes you'll need twice the length
and yes connect the fuse within 18 inches of the battery if possible.
I have all this wire and i could sell it to you btw, feel free to PM me
alright bro ill think of taking that off your hands. just to make sure im getting what you mean, this is all i would need?
http://www.knukonceptz.com/productDetail.cfm?prodID=KOL-AK8
8ga amp kit
http://www.knukonceptz.com/productDetail.cfm?prodID=KND-23
distroblock
http://www.knukonceptz.com/productDetail.cfm?prodID=KLMX0BL
1/0
http://www.knukonceptz.com/productDetail.cfm?prodID=KLMX4BL
4ga for distroblock to amp and then amp to ground
http://www.knukonceptz.com/productDetail.cfm?prodID=KLMX8BL
8ga sub amp to subs
http://www.knukonceptz.com/productDetail.cfm?prodID=KLA-5M
rca HU to amps
http://www.knukonceptz.com/productDetail.cfm?prodID=KLE12BL
12ga speakers to comp amp
http://www.knukonceptz.com/productDetail.cfm?prodID=ANL150
fuse
also is it smart to get two amp wiring kits or just buy the seperate wires
is this all i need in total for two subs, 4 door speakers, 2 amps
100ft of 10ga (which ill use when i get my subs thats why im just buying alot of 10 and not 12)
(2x) 8ga amp wiring kit http://www.knukonceptz.com/productDetail.cfm?prodID=KOLAK84
1/0 to the trunk
distroblock
and the kit comes with rca's
150amp fuse
do i need side battery terminal things?
does the distroblock to amp and then for mp groudns have to be 4ga? or will 8ga work?
taintedplay
taintedplay
dallas
taintedplay
Old_risk
    Jun 23, 2026
Old_risk
    Jun 23, 2026
