wiring bluetoot into old car stereo?
  • 5
RockyBalboa
CarAudio.com Recruit
26
Dallas
I am looking to add bluetooth to a older head unit with hopes of it being non visible from the outside of housing. I ordered a universal bluetooth unit that I am going to hard wire into my aux port on headunit. This should work fine but also want to use my cell phone for navigation while lisening to the fm radio , so I assume I need to also tap into the fmradio out put some how. Any one have Ideas on where to start.
wiring bluetooth into aux port only allows me to use bluetooth when head unit is in AUX mode.
I would like the bluetooth navigation , recieve phone calls, while fm radio is in use.
eh , you guys are no fun. The module works fine. I tapped into the aux input jack. It works the same as if you plug it in from the face, only no wires visible. Works the same , just no visible wires from the face since its hooked up inside. Easy, 3 wire hook up. I didnt get all I wanted by overiding the radio system but I did get wireless blue toot. Running the radio through the fone , the gps and fone calls will still operate as I would like.
Deff need to lnow what subs.. Make and Model# would help quite a bit. What amplifier will you be using?
86
359
352
Box rise, more accurately, impedance rise, is the reactive load changes the woofer exhibits at different frequencies and it will happen, it's...
663
RockyBalboa
RockyBalboa
Dallas
RockyBalboa
    May 16, 2024
    May 16, 2024
